It is currently Sun Oct 05, 2025 9:29 am
PostPosted: Sat Dec 06, 2014 11:30 am
Left clicking the start button at the bottom of the screen only sometimes opens the start menu. It usually opens the metro unless I press the windows key to open the start menu. I have not found any consistent reason for this happening. I have checked to make sure that the left click opens start menu is checked. The Classic Shell Utility log is attached.
classicshelllog.txt [115.83 KiB]
Downloaded 938 times
PostPosted: Sat Dec 06, 2014 11:40 am
Maybe it depends on the point where you click?
Do you use the default Windows start button, or the one from Classic Shell?
Also, is this a new problem or just appearing recently, like after a Windows update?
PostPosted: Sat Dec 06, 2014 11:43 am
It doesn't appear to matter when I click. This is a recent issue. It appeared a couple days after i ran updates.
PostPosted: Sat Dec 06, 2014 11:45 am
There is a known issue with Avast and the latest KB3000850 update. Can you try temporarily uninstalling Avast to see if it is related?
PostPosted: Sat Dec 06, 2014 11:47 am
I will try uninstalling avast. I uninstalled the KB3000850 update
PostPosted: Sat Dec 06, 2014 12:19 pm
I have uninstalled avast and the issue still occurs. The last thing I can remember installing before the issue started occuring is the game Insurgency
PostPosted: Sat Dec 06, 2014 12:23 pm
After more vigorous testing it does appear that this issue only occurs depending on where I click on the start button. The area that causes the issue is the bottom left corner.
PostPosted: Sat Dec 06, 2014 12:25 pm
disabled active corners and the issue is resolved. Thanks for your time
Users browsing this forum: No registered users and 177 guests
